I am looking to replace my sagging coil springs on the rear of the bird. I went to my Ford Dealer & they are not available anymore. I went on the web to find if anyone had a set & came up empty. The Part # is E7SZ-5310-K.
So I go to NAPA and another local parts store and they both can get coil springs for me -the NAPA Brand or TRW. Each one has a progressive rate or constant rate spring. Which one should I get? They said that the spring is the same for an 85 thru 88 Turbocoupe and the V6. Could that be true with the electronic suspension? I got a price from Coilsprings.com for $118.00 per pair + $32 shipping. The TRW ones are $55.00 a pair & the NAPA ones are $49.00 each or pair (not sure on last one). I looked at my cars certification label on the door jamb for the springs and they showed TTKK - TT for the front & KK for the rear. My parts book does not list springs by year or motor, just by the code on the door jamb. Can anyone check their cars to see if you have the same codes.
Finally, I also saw in some posts that one side is usually lower than the other (A common FOX platform problem) and I want to make sure that this does not occur with the new springs. Anthing special needed to prevent this from happening or will the new springs correct that problem.
As always...looking for word of wisdom from the knowledgable.
Tony Sceia
Red 88 TC loaded with every option, Walbro 255, 3" SS Downpipe with Magnaflow SS 2.5 Cat Back Mustang Dual system Installed by BJL, 3-core Radiator, Star Stage 2 Clutch, Rebuilt T-5 Tranny, 140 MPH Speedo
Now I need to finish converting to Raven/Gray Leather interior & just do some Body work & she'll be like new.
Tony Sceia
Tony Sceia -
HIS Red 88 TC
HIS Red 88 TC
