Stinger FMIC install questions.
BabyBlueBird Offline
#11
Brad, what pimpx system did you buy? They sell a bunch of different types. Not sure which one I’d need.
BradM Offline
#12
There is only one PiMPx that's for our 2.3's. The "x" is for batch fire injection. That's us. PiMPxs is for sequential injection.
#13
Bluebird, you mentioned that you wanted a FMIC first and then downpipes and such, may I recommend you get the exhaust first and run the stock top mount cooler. Opening up the exhaust on my first IHI made a super fun daily driver with near instant boost building and power. Do that and a good fender well mounted air filter instead of the stock filter box will be a very noticeable increase.
Jeff K likes this post
#14
Kuch, I was thinking for the time being just running a cone filter at the end of the vam and when I go through with the Vam delete I make a fender mounted intake.
Brad what upper radiator hose do you have on your car? The previous owner of mine put a daycore hose on mine and its too short to fit the intercooler pipe around it.
BradM Offline
#15
I used two different hoses with a coupler (ICT Billet 1-1/4" to 1-1/4" Inch Hose Barb Splice Coupler Repair Fitting Adapter Connector Radiator Coolant Intercooler Heat Exchanger Fluid Designed & Manufactured in USA Bare Aluminum AN627-20A). My upper hose did not fit well under the FMIC charge pipe. I combined the hose on the car plus a GATES 21163. The hose on the car looked very different than the Gates, which RockAuto said was a replacement hose and would not work at all. The one on the car looked like a DAYCO 71555. I'm very happy with the fit now. You can see where I spliced the two here.
Attached Files Image(s)
#16
So just to confirm, you used a gates 21163 plus what looks like a dayco 71555 to make that hose?
BradM Offline
#17
Yes as described.
