TheBullMoose
Nov 2020
Norfolk, Virginia
Howdy!
Does anyone know the correct part number for the rear steering stabilizers on an '84? I've been looking on Summit, Rock auto and O'Riely but every one I order turns up being the wrong size.
Thanks for the help!
88Slowbird
May 2019
Tampa, FL
(03-17-2025, 07:23 PM)TheBullMoose Wrote: Howdy!
do you mean the quad shocks? the sideways shocks on the rear that connect to the rear end
1985 TC 5 Speed: Steeda Tri-Ax Shifter, Big R Stage 1 T3, Stinger FMIC
I'm not sure which part exactly that you're looking for. The quad shock has been mentioned. I got these, but there are others on LMRs website.
https://lmr.com/item/KON-251215K/koni-mu...pair-84-04
If you're looking for a rear stabilizer bar, I put this one on my car.
https://lmr.com/item/EIB-3510312/79-04-M...i-Roll-Bar
I'd highly recommend putting their front bar on as well, made a huge difference on my car.
If you're looking for rear shocks you can use any rear shock for an SN95 Mustang but you'll need brackets from these guys to make them work.
https://23parts.com/
There are no replacements for the factory ride control shocks on these cars unless you happen to find a set that either used or new that someone has squirreled away.
TheBullMoose
Nov 2020
Norfolk, Virginia
03-21-2025, 12:47 PM
(This post was last modified: 03-21-2025, 12:48 PM by TheBullMoose.)
(03-18-2025, 08:34 PM)88Slowbird Wrote: (03-17-2025, 07:23 PM)TheBullMoose Wrote: Howdy!
It seems I do, yes! I always heard them referred to as steering stabilizers, apologies!
Looking for something at factory spec if they can be had. Don’t want to spend a fortune on them if I can help it.
88Slowbird
May 2019
Tampa, FL
here's a few part numbers for them
Gabriel 14039
MONROE 32242
KYB KG4521
