teal95
Dec 2002
Grass Lake, MI
I replaced the steering rack in the gold car last weekend. It was leaking out the passenger end bad enough that I had to put fluid in it every day. Needless to say the underside of the car on that side is well lubed. I got the rack in and when I went to bleed it I had a major leak. After getting Dad to get in the car and start it for a couple of seconds while I watched the fittings I found it was the pressure line. As the line was tight I decided to take it off again to check the o-ring at the bottom. It wasn't there. After some fishing in the fitting in the rack I retrieved the o-ring and compared it to the one I took out after I retrieved it from the trash can. The new one was bigger, it's no wonder it fell off. I put the old one back on but then ran into a problem. The teflon seals at the top of the line was destroyed from taking it off again. And now I can't find the teflon seals anywhere. Any ideas on where to get the seals?
steve
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
87TurboBobby
Dec 2006
Colquitt,Georgia
I had a friend that worked at Advance Auto Parts and he robbed the seals off a new power steering pressure hose for me. That is the only place I could find them. Worked great after that with no leaks.
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
vegas_ss
Jun 2005
Las Vegas, NV
If you have a harbor freight store in your area, they have assortments of O rings and seals including teflon. You have to buy the kit (different size assortment) but they aren't too much $$$.
teal95
Dec 2002
Grass Lake, MI
I couldn't find them at Harbor Freight but I found that they are available from Ford. The part numbers are 388897-S and 388898-S.
steve
3x '95 & '96 GT
BJL
Williamstown, New Jersey
the local auto parts store (not a chain, its a mom and pop's type store) has a bunch of these in stock under the "help!" brand, i always keep a few packs in my tool box for the times i stretch them to much putting them on...
Brian Larkin
88TC 330,000 miles
Slightly Modified
87TurboBobby
Dec 2006
Colquitt,Georgia
Brian,
You don't happen to know the Help part number do you? I'd like to get a pack or to to keep on hand.
Thanks
90 Mustang GT Vert.
95 Mustang Vert
04 F150 Heritage
92 Chevy Silverado
(06-07-2008, 10:49 AM)87TurboBobby Wrote: Brian,
Thanks
Only delayed by 12 years, but I think it is 82540.
1931 Deluxe Coupe
1949 Club Coupe
1951 F-1
1971 Torino GT Convertible
1988 Thunderbird Turbocoupe--SC-50 turbo, 3" Motion Dynamics exhaust
teal95
Dec 2002
Grass Lake, MI
I don't even have that car anymore, but I do have it's replacement still. I have a bunch of Fox Mustangs though so I'm sure I'll still need it again at some point.
steve
3x '95 & '96 GT
