steering problems
Huey866 Offline
I have a steering or suspension problem in my 88. When I hit a bump driving down the road the car will either wonder either to the left of right. Usually it wonders to the side that the bump was on. Its kinda scary when It does it. Ive been told that it could either be the struts or the steering rack. Ideas? Thanks.
87 TurboCoupe - silver, 137k, 5-speed, 3.73, 5 lug swap, MM... Evertything, 03 Cobra Brakes, Griggs Subframe connectors, Bo 1.5, Big Valves, massaged 79 turbo head, Essy Cam Gear, Boblog + Elbow, .63 T-3, Stinger Exhaust/FMIC
thecrusher315 Offline
It could be either one or a combination of worn parts. Does the steering have a lot of play in it? If so it could be the rack. Does the car have a lot of bounce on the front driving down the road? If so it could be the struts. The ball joints or lower control arm bushings being worn out also might be a cause. Check the ball joints and control arm bushings for play. Check the ball joint wear indicators and visually inspect the control arm bushings. Bounce the front corner of the car with your body weight and see if it continues to bounce after you let it go. Usually no more than 2 decreasing bounces after you let it go. If more, the struts might be wore out. Have someone turn the wheel while the car is on the ground and you are looking at the tie rod ends on the rack. If you see excessive movement in the ends before it starts turning the tires then that would indicate a bad rack and or tie rod ends. Hope this helps....Tommy
Tommy Moore,
Paying NATO Member and proud of it!!!
Code 33 Silver Blue Clearcoat Metallic 1987 Turbo Coupe, Shadow Blue interior, 5 Speed with Spec stage 2/3 clutch/pressure plate, Hurst shifter, Gillis valve, 140 mph speedo, Auburn Posi unit with 3.73 gears,Flowmasters, KYB struts, shocks , and quads, 2nd and 5th owner of the car. I just had to buy it back.
[This message has been edited by thecrusher315 (edited 10-11-2005).]
