I have installed a Super Coupe steering wheel and column. I like the switches and the wheel much better. After finding out the SC wiper motor is reversed from the TC and the wipers won't be able to park an no hugh speed, the main issue I have is the wheel is turned 30 degrees left to drive straight.
Is there a way to rotate the knuckle connector at the bottom of the column?
I already looked at moving (turning) just the wheel but that won't work. I really don't want to bring it to an alignment shop an have them do it, if I can fix it.
Thanks.
Thanks.
88 Blue TC, 3" exhst (dn pipe/hi flo cat/Dynomax) to 2-2.5" tailpipes, man boost cntrl, SuperCoupe rad/FMIC w/fan, bpv, 9" K&N, 130A alt, Lincoln frnt clprs, subfrm connectors, Saab airdam, Supercoupe steering colunm/wheel, auto to 5 spd, UPR shftr
