steering hoses
skydiver Offline
all hoses that go to the rack are rotted/leaking at the rack itself. can i use generic fittings with 3/8 hose or do i need actual replacement hoses for some if not all fittings? i figure if i'm going to do one, i might as well do'em all.
drivin' a turbo
flyin' a turbo zx
turbobird Offline
The pressure hose coming out of the pump must be replaceed with the same kind,and they are not cheap!
Jerry Rutten
88'Turbocoupe
Jerry R.
88'Turbocoupe
Thats for sure! I paid $60 for the high pressure pump to rack hose almost 2 years ago!!
skydiver Offline
i expected as much on the hose to the pump. it's the others i was wondering about. all help is appreciated.
For the low pressure return lines, I just use tranny cooler hose.
Chris Ruhl Offline
For the lines you could also use high pressure hose with hose clamps.
