Steering Column Firewall Gasket
John B Offline
Does anyone have the firewall gasket that the steering column goes through for an 87-88 TC? Mine is ripped pretty good and I would like to replace it while the car is apart
88Slowbird Offline
automatic or manual? they're different since on the manual cars the clutch master mounts on it
1988 TC (Mach 1 edition): Steeda Tri-Ax shifter, manual boost controller, Stinger FMIC, Forge blow off valve
1985 SVO: Pro 5.0 Shifter, Boport valve springs, Ranger R Cam, Manual boost controller
John B Offline
To be honest, I'm not sure it matters for my application. I have a 5sp but I'm converting to a clutch cable for my TKX transmission. I can imagine the automatic one would be better here but I'll take either if it's not ripped lol
88Slowbird Offline
(06-29-2023, 06:52 PM)John B Wrote: To be honest, I'm not sure it matters for my application. I have a 5sp but I'm converting to a clutch cable for my TKX transmission. I can imagine the automatic one would be better here but I'll take either if it's not ripped lol
I have an automatic one I'd sell
I 5 speed swapped my car so I tracked down the manual firewall boot
John B Offline
Just sent you a PM
