TCorBUST
Nov 2001
Manchaca, TX
Does anyone know of a source to get a steel bearing retainer for an '88 TC?
I guess the mustang v8's won't work, right?
Thanks
'88 TC 5sp, K&N cone, t3.60/.63, ported head, Felpro 1035, Walbro 255 hi pres., Kirban FPR., 3g Alternator
Dan E
Greensboro, NC
I think the V8 T5 ones are the same. The Input Shaft is a different length and the diameter is different on the end for the pilot bearing...but I think that the retainer is the same ?????
Try Summit or Holcomb Motorsports.
Dan Eaves
Dan Eaves
tps87turbo
Feb 2003
Hammonton, NJ USA
They are not the same as the V8 models. Most 4 cyl models have a small front input shaft bearing, while 1 or 2 early 85-86 4 cyl models have a large front input bearing as the V8 ones. When I did my tranny, I called Dave @ Hanlon Motorsports and he helped me get the right one. They are very knowledgable & helpful & I highly reccommend them. If you give them the Tran Id off the tag, they will tell you if you can use a Steel Retainer or need to use the aluminum one. Look in the vendor section for their website.
Tony Sceia...Got a TC, Started working on it & progressing very slowly. Hope to have her running by the end of the summer.
I know the steel ones made by D & D won't fit the 87-88 T5, only earlier T5s
DrPhang
Petersburg, Virginia,
http://www.hanlonmotorsports.com/ has them for like $45
HMS027019 BEARING RETAINER $45
. BEARING RETAINER FOR 4 CYL TURBO ALUMINUM
I have one sitting in my closet...it is an offical Borgwarner replacement part [Image: smile.gif]
Dr. Phang, Thanks for that info. I'm going to put it in the Part # forum.
TCorBUST
Nov 2001
Manchaca, TX
Yes. Thanks!
DrPhang
turboken
Denison , TX , USA
I KNOW that the moostang retainer wont work. the very front bering thing (race, ???? contacts the bearing and retainer) doesn't fit. I measured the diameters to machine my 5.0 part, but haven't done it yet. I don't get on the internet often, so if you need the dimensions, email me at [email protected]
l
88TC- all options minus leather: 129K miles, new motor, bored and balanced block, roller cam(FordMotorSports), Crane ignition and coil. Powerhead with big valves, ported intakes and exhaust, 5 spd with FMS rebuild kit, B&N ripper shifter, K&N cone,
9.564 in the 1/8 mile
93 SC with all options minus the JBL system. Stock with drop in K&N filter and no cats.
9.716 @ 72.507 1/8 mile
88TC-Black/Raven,A237 cam,ported and polished intakes/exhaust, gillis valve, o-ringed deck, head studs
85 Xr7 rough survivor 82k miles
2008 Subaru Impreza non turbo :-(
73 Honda CB750 (running parts bike for dads '69)
04 Honda 1000rr
