Starting (wiring?) ploblem
rod6780 Offline
My 88 wouldn't crank I changed the silinoid cable ends.It started I shut it down and started it again and the starter keep going. Turned off the key and the motor quit but the starter kept running until the battery went dead. What could cause this. It has the Ford Security System which has been hacked. A button has been added next to the coloum you have to push or you get a clicking.
Sounds like either the solenoid contacts welded them selves together or some thing is sending power to the solenoid, even when the key is off
