starting problems?
ForceFed2.3 Offline
I was wondering if anybody has an idea why when my car is cold it starts up fine but when it warms up and i shut it off and try starting it again you have to crank it over for about 3-4 seconds. I can't figure out why my car has really bad throttle response, when you tap the gas it seems like it wants to die, it will dip down then go up almost wanting to die.
PLEASE HELP!!!!!!!!
Thanks, Jason
[This message has been edited by ForceFed2.3 (edited 01-26-2003).]
Dan S Offline
My '84 had the same problem which caused a lot of frustration until someone on the site suggested I change the fuel pressure regulator. That solved the problem on my TC.
Dan S
Dan S
1972 Ford F-100 SWB Styleside
2015 Lincoln MKC 2.3 EcoBoost AWD
Pull the codes and check the fuel pressure
MEasure the rate fuel pressure drops off after you shut the car off. Should only drop a few pounds after 5-10 minutes. If it drops faster than that, either the FPR is bad, the check valve in the fuel pump is bad, or you have a leaky injector. Does it shoot out a puff of black smoke when it starts after the crank when it is hot? If so, probably a leaking injector.
Chris Ruhl Offline
I would check the fuel pressure also, and I would also look at a ignition module problem.
Nate K Offline
Don't overlook the obvious, a clogged fuel filter. Fuel filters should be changed about every third oil change or every 6 mths. I would start there, if problem still exist, test the fuel pressure as Jeff stated.
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
