Starter Problems
Just want to verify a problem. The starter on #2 bird spins when I hit the key but the drive gear is not engaging the flywheel. I assume it's new starter time?? Feedback please. It was working fine an hour ago.
and jack rails.
tylerport Offline
Pete, you may just need to get a new Bendix installed. I'd take it somewhere and have the Brushes and Bearing checked while your at it. Some places can do that kind of work, while most just exchange.
Jim Portteus
86 Turbo Coupe, 128K Miles, 140MPH Speedo, Gillis Valve, 2 1/2" Downpipe to 2" Duals w/ 12" Glasspacks, 245/50R16's and new paint. Check out My Home Page
Jim Portteus
turbocoupeterry Offline
need new starter
88 tc, new tires and a k&n filter fender mounted
1987tc Offline
You can put a new bedix in it as well as new brushes. By then you will be close in price to a rebuilt starter. Depending on how good a rebuilt one you get.
How old is the starter? If it is not to old you can repair it and have good results. If it is old or is original then it is time for a new one. I will not bother to repair a starter or alternator. My time is worth more then that to me. I would rather spend it on projects that are more interesting.
Wes
1987 TC:
Hurst compition plus shifter,K&N cone,roller cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear.
Tubular rear control arms and Kenny Brown trac kit brackets. soon to come, Installation of Caster camber plates and a custom built roll cage.
Wes Arnett
Linton Indiana
JT Offline
Wes
i agree. If you are going to spend the time to remove the starter, you might as well just replace it.
And if you do, go with a Ford unit. Otherwise, you will probably be doing it again, soon.
JT
JT
[email protected]
www.geocities.com/turbocpe/
1987 T-Bird Turbo Coupe T-5
1994 T-Bird LX 4.6L
1988 T-Bird Turbo Coupe A4LD
1988 T-Bird 3.8L
1979 T-Bird Heritage 351M
Dan E Offline
Pete, if you take the cover off the top of the starter you can see that there is an pivot arm that is held by a pin that actuates the starter gear. This pin can work its way out and the arm will be hanging loose...and thus won't engage the starter gear. It's worth a quick look.
Dan Eaves
Thank you all for the responses. I should have added that this is a reman unit w/ less than 3K on it since installation in March. Given the way it went down, I'm inclined to go with Dan's idea. I'll pull it off tomorrow and take a look. There is a warrenty on it so I can always exchange it.
and jack rails.
JT Offline
JT
See what i mean? Sorry to hear that Pete.
But thats why i said what i did. i, too, had to learn that.
JT
JT
[email protected]
1994 T-Bird LX 4.6L
1988 T-Bird 3.8L
