1fasttc
Sep 2006
Yuma Arizona
the car seems to stall on me every stop,then when it stalls on me while im driving it turns back on with a back fire? is it the fuel injector problem i have or is it another problems.Thanks for the help!
Backfire can be a timing issue. Have you checked cam tining (first) then ignition timing. Note how steady or not the ignition timing is. How many miles on the cam drive belt?
http://www.turbotbird.com/techinfo/CamTi...t%20Up.htm
There can be other causes too. How fresh/old is your tuneup and what brands of parts. Have you checked the TPS voltage and cleaned the IAC
http://www.turbotbird.com/techinfo/Idle-...e2005.html
