whiteacid
Jan 2002
Aiken, SC
Hey everyone, I have this highly annoying squeaking coming from my front passenger tires. It started when I went to the lake and went down numerous dirt roads. I *think* its dust in the calipers, but I am not sure because it doesnt seem to be going away. I have tried taking the tire off and lubricating the calipers and pads, but it still squeaks. Please help me before this noise drives me insane and causes me to shoot a hole in my tire! Thanks, Will Jackson
TurboZeke418
Mar 2002
Freehold,NJ,USA
is it a steady "brake" soundig squeek, or does it sound like a heavier deeper squeek that only only happens when the car suspension moves. thats what I have. I think i have to change all of the rubber components...they look dried out.
1988 Turbo Coupe, Auto, Loaded everything including leather and Moonroof, 50,300 original miles, garaged since new, MINT condition
1994 Lincoln TownCar- Seafoam Green and beige leather, another beautiful find that couldn't be passed up!
2003 Dodge Durango SLT+ 4x4
Dan E
Greensboro, NC
Yeah, mine has a new rotor and caliper in the front left and I still have a squeaking sound.
My next project has got to be to replace my ball joints and all of my control arm bushings (front and rear) !!!!
Dan Eaves
Dan Eaves
whiteacid
Jan 2002
Aiken, SC
It will squeak constantly but when I tap the brakes it goes away.
TurboZeke418
Mar 2002
Freehold,NJ,USA
dan.....let me know where you get those parts or the numbers. I have to do the same thing!
86tc
Jan 2002
Jonesburg, MO, USA
If it stops when you tap the brakes, it seems to me that the brakes may need changed. Check your brakes and see if they are getting low on pads. Disc brake pads are now equipped with what they call "squealers" or "squeakers" to let you know when the brakes are getting worn too low.
Rick
'62 Ranchero (in progress...again)
'72 Gran Torino Sport (for sale/trade)
'76 Honda CB750 (for sale/trade)
'88 Yamaha Blaster Race 4-wheeler (for sale/trade)
'89 Lincoln Town Car (for sale/trade)
'92 GMC Safari Conv. Van (for sale)
'94 Pontiac Bonneville
'96 GMC Jimmy
Dan E
Greensboro, NC
Well, mine does that too...stop when I touch the brakes I mean.
It did it before I changed the rotors and pads...and it still does it afterwards ????
I repacked the inner and outer bearings on the rotors too !!!
It's really bothering me since I thought my brake job would take care of it...so all I can think is maybe it's the ball joint allowing the spindle to shake and touching the brake stops the spindle from moving a little ????
I'd like other opinions !!!
Dan Eaves
BJL
Williamstown, New Jersey
Well i fixed that on my tbird by take int eh eadge of the brak bad and gridnign the sharp ege off, my bos scalled it tappering the eded, ti had to dewcribe what id id cuz i cant explain it, it stop my squeaking, but it came bakc but i have a set of Remsa pads to go on cuz i enevr ha da chnace to ptu them on, have the remsa in the back, no dust or niose, the remsa i used at Meineke for liek years and snver had a problem, and has a lfietiem warranty too
Brian J Larkin
1988 Turbo Coupe 5spd, dark blue and shining like a peice of polished glass.
http://crazydriver358.5u.com
Brian Larkin
88TC 330,000 miles
Slightly Modified
Turbojet
Feb 2002
Connellsville, Pa. USA
When you replaced your pads did you place some grease on the metal ends that slides in and out on your caliper? I did this with mine and so far no squeak.
The Family:
86
87
88
Dan E
Greensboro, NC
Yep...but I am thinking about changing brands !
Dan Eaves
