TwoTireFire
Dec 2001
Pittsburgh, PA
Guys, I have a problem that is driving me nuts. I have this awful sound coming from my right front corner whenever I hit a bump or turn hard to the left. The sound is only there when the ride control is NOT in firm mode. If I have firm mode engaged the sound is not present.
I've had the wheels off, with the car up on a lift and I can find nothing wrong. The only thing I can think of is that something is messed up with that strut that makes is squawk when the dampening in reduced.
Any input?
87 TurboCoupe - 5 spd, 60K
Unfortunately there are lots of things that can make noise in the front ends. There are rubber cushions at the ends of the springs, I think. Also strut bushing, sway bar bushings, A arm bushings. Might also want to check tie rod end links (2 inner & 2 outer) and ball joints.
TwoTireFire
Dec 2001
Pittsburgh, PA
I've gone over the suspension carefully two times now. Once about two weeks ago prior to inspection, and now once again since it started making noise. I'm almost certain that it has something to do with the strut itself, but I am not sure how to verify it.
Blade1433
Jun 2001
Columbus, Ohio, USA
Well, now that we're on the subject of funny noises... When I make faster right hand turns, my drivers side front end kinda groans. I know it's time for a rebuild, so I'm going to rebuild and forget the damn thing. I think I'm going to get a PST front end kit. Why? If you go to a local parts place you're gonna spend close to $225 for all the parts or you can go to the website and pay $190 for everything and thats with poly graphite bushings not rubber.
My noises are weird. I get the groan in firm or auto suspension modes. But I get a chatter in soft mode too. To clarify there's only a chatter in soft, but there's a groan in both...
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy, almost all options with new U-joints, tranny Xmember, front end, FULL tune-up with select MSD products, new horizontal axle shock thingies, custom interior, white face guages. Coming soon: boost guage and air fuel ratio guage on the pillar, Gillis valve, K&N, gutted upper, knife edged lower, gutted E6, T3, and steam cleaned engine bay.
[This message has been edited by Blade1433 (edited 02-15-2002).]
TwoTireFire
Dec 2001
Pittsburgh, PA
CHATTER: You nailed it on the head Blade. Mine chatters in soft, but I don't notice any noise in firm. Of course that could be becaue my teeth are chattering too loud from these rough-ass Pennsylvania back roads.
What's this PST kit?
Blade1433
Jun 2001
Columbus, Ohio, USA
www.p-s-t.com
It pretty much replaces everything on the front end with the exception of inner tie rod ends($40 for both) and spring isolators($30 at Summit). I've priced out everything at the parts store and they come out pretty close in price, but these are performance oriented parts.
Blade
