sprung a leak...
ridgeback Offline
So the bird was dormant for about a month, itching to get her out and finally a nice dry day so out of the garage she goes but not before I quickly check oil level. Pop the hood as she is warming up and WTF now! (see link for pic) Exhaust manifold by the front of the engine is slowly bubbling along the top edge of the iron against the head. A nice white residual is all that's left once the manifold heated up. Coolant level appears to be OK so if it my coolant, it must have just recently happened or its leaking very minimal amounts. No misfires, engine runs like a smooth monster at all RPMs.
So guys, what am I looking at here? cracked head?? is this a common failure area for the head or manifold??
https://www.dropbox.com/s/vzwngze6rriyi0...y.jpg?dl=0
Ron
Black 87 TC, 2nd owner since [email protected], [email protected]
My guess is that if that is coolant, and there isn't much else it could be besides oil, then the coolant is coming from one of the metal tubes/connecting hoses running along side the head, back to the heater core. The coolant tubes can rot out and leak.
RC Martin Offline
I've had that exact same leak, just not as bad. The hose probably dried up a bit. Tighten the ones above that spot and you should be good to go!
^^^^^ Agreed. The 90 deg hose from thermostat housing to the coolant pipe running along the VC is likely leaking under pressure.
ridgeback Offline
Ok lets say it is a coolant leak from the thin line just above... I do see small bubbles along the fit of the exhaust manifold and the head indicated by the red line i drew on the pic... could that just be a very small exhaust leak soaked by the leaking coolant line? I am hoping that's the case, sounding the least expensive. I will take a closer look once I get rid of my crippling sore throat virus.
thanks guys!
Ron
Ron, There is no gasket between the manifold and the head, from the factory, on a turbo 2.3. There is an opportunity for small amounts of leakage, after 30 years. This would be especially true during warm up.
RC Martin Offline
It could also just be hottest spot and boiling off at that edge...
ridgeback Offline
Pete your dead on... it was on a warm up when i noticed it so I have my fingers crossed that its a simple coolant leak from above.
I will follow up on it when i get a chance to take a close look.. too cold now.
Ron
