Grant
Jul 2002
Thomasville, GA
It seems that everyone who has compared different stang/ bird coil springs agrees that the sn95 springs are the closest match for us. Sooo, why not use a nice new set of sn95 lowering springs? Most of them are ~1.5-2" drop, and someone has said the stock sn95 springs are a touch taller than ours, plus our cars surely are lighter than a sn95 V8 (especially if vert springs were used). What do you guys think?
83 TC : full 3" exhaust, 17" 93 cobra wheels, many mods awaiting install once the engine's back in
Joe F
Jul 2002
Hawkins, Texas - USA
I've got to ask a real dumb question here. I've searched for the answer but can't seem to find it. I see references to "sn95" quite often, and it's begining to drive me crazy. What the heck is "sn95"?
Duh?
[This message has been edited by JoeCool (edited 11-05-2002).]
Refers to the SN95 platform for the Mustang
94 and up Mustang to be exact. The SN95 platform is also known as the Fox4 platform, which is a strengthened version of the Fox3 platform our cars use.
Joe F
Jul 2002
Ahh! Now it makes sense. Thank-you thank-you. One more mysterious reference demystified.
Have a GREAT day, all!
Cheers!
Joe
Original Owner 87. K&N filter, Gillis @ 15psi, MSD-6AL, Magnecore 10mm wires.
BCA
May 2001
Dowagiac, MI
BCA
Grant,
No experience here, just a guess; but it seems to me that if the stock SN95 springs are being used to lower the car to an acceptable level of 1.5"-2" then a set of springs that are designed to lower an SN95 car might lower the TC too much for normal use.
Brent
1985 Cougar XR-7 5-speed: Child & Albert 5.7" Super Sports Rods, Custom Wiseco Pistons bored .030" Over, Childs & Albert ZGS Rings, ARP head studs, main studs & rod bolts, Ported Big Valve Head w/Ranger Roller Cam, Port Matched Intake w/ ’88 Lower, Motorsport Front Mount Intercooler, Ported E6, Esslinger Main Strap Kit, Original T3, Gillis Boost Valve, 3" DP w/No Cat & ’88 TC OEM Dual Exhaust, K&N, ’88 TC Front A-arms & Spindles w/ 73mm Calipers, ’88 TC Rear w/Disc Brakes, 3:73 Gears, Eibach Pro Kit, Koni's, Energy Suspension sway bar bushings, Hella headlight conversion, 140 Speedo.
1986 asc/McLaren EuroCoupe - 1 of 47 made
1971 Ranchero
Hi-Jumper Sandrail w/2.3L Turbo Power
1971 Ranchero GT
Chuck W
Indpls, IN,USA
I use the stock SN-95 springs on the rear, but I wouldn't use a lowered set..too low. As for the fronts, stock SN-95 psrings would most likely raise the car a bit...Lowering springs might work....I mean, I use lowered Fox springs (motorsport "c"s) on the front of mine..HOWEVER, I think alot of the SN-95 springs lower the cars more than the C's did on the Fox cars to try and loose alot of that huge gap between the tire and fender...so they might be too low.
83 Pseudo-Coupe, 87 Ranger (soon to be 2.3T), 84 XR7 (Yes it will live again!), and 62 Mercury Monterey (old n slo)
NATO Member since the beginning!!!
Grant
Jul 2002
Thomasville, GA
Thanks guys! I was under the impression that the sn95 springs were about the same as ours, but most of the aftermarket ones are for 2" lowering! I saw some pics of Ken Skila's, which had Motorsport sprongs on it, and liked the stance of it a lot. I'll probably end up w/ some of those. Later
