trashline
Feb 2005
Levittown, PA
damn I knew i forgot something. the spout was in when i set timing. reason being was i didnt do it. my fathers friend did it. ill effects from this? he set it to 10 degrees advance with spout in so i guess i should fix this tomorrow. this could be the problem of my lack of power higher up.
1966 mustang
1988 tbird
Originally posted by: fordprefect
Mine sounds like twenty crickets on meth!
Ryan H
Oct 2004
Panama City, FL
YES. Correct me if I'm wrong, but I believe your EEC is actually RETARDING the timing up top when you set it like this! I had the same problem when I couldn't find the EEC disable jumper on my grandma's Geo.
Ryan Harris
88 TC, 5 spd, B&M Ripper Shifter, Walbro 190 LPH, Aeromotive FPR, K&N, 3.73 rear, KS disconnected, BCS bypassed, 89K miles
'88 TC Walbro 255HP, Stinger FMIC, PIT BOV, Pro 5.0, Kirban, RR cam, FRPP strut tower brace, T3
Ryan is right.... at 1000 RPM hot idle, computed timing is around 28 deg. With timing set to 10 deg with the SPOUT plug in, the whole timing curve is about 18 deg retardrd from where it is supposed to be. I'll bet that thing can barely get out of its own way with the timing set like that!
I did something sort of similar when I was going through the white car. I set the timing, spout out, then forgot to put it back. I went for a test drive and couldn't figure out where the performance went. That lasted abut a minute, then I realized what was going on. It does not run well on 12* total advance
trashline
Feb 2005
Levittown, PA
so this is probably my WOT problem then and not the fuel. im buying a timing light and doing it myself. Im a little pissed b/c I even told the guythe spout had to be out. oh well.
1966 mustang
1988 tbird
Timing that retarded will make the car feel as powerful as an SUV powered by a lawn mower engine.
trashline
Feb 2005
Levittown, PA
so i re did the timing. with the spout out. it was aprox 14 degrees off. with the spout in timing read around 24 degrees. i set it to 10 degrees btdc. i hope it isnt to bad now. lol.
1966 mustang
1988 tbird
trashline
Feb 2005
Levittown, PA
WOW I feel ike i just woke upa sleeping giant. this thing moves like a cat. cant belive the difference haha. i can see a blown HG again. j/k i hope not. stil has crappy idle issues.
1966 mustang
1988 tbird
Finally have mods that I can post... 373 gears with a brand new t5. K&N cone. Gillis set to 15 psi. Walbro 255 lph. Kirban afpr. Kelly Evo Z tires. Energy suspension front swaybar bushings. Rebuilt topend with stock components.
Working on a FMIC w/ the stock IC.
PetzJC
Feb 2004
California, MD
Quote:Originally posted by Pete D:
.....then forgot to put it back.....
That forgetting thing is happening more and more often, isn't it Pete......
88 Silver T/C, original owner, 264,000 miles.
Loaded with everything except leather & auto trans.
Short block & turbo original/untouched.
Spec-II/III combo clutch assembly.
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16's.
Yes it is......uh...uh......John
