I found this trunk and spoiler at the junkyard!
I am not sure if I like the look of the 3" tailpipe. Does anyone have a suggestion to make it look better?
1984 Turbo Coupe
Rebuilt Engine
New T3/T4 Hybrid Turbo
Large Spearco Intercooler with Bypass valve.
Adjustable cam gear.
Kirban adjustable fuel pressure regulator
K&N fender mounted filter.
8.8 readend with Ford Motor Sport 4.10's
Replaced entire brake system
Replaced entire fuel system
Replaced entire suspension
87' or 88' TC hood
Completely redone leather interior.
Turbo boost adjuster from Tiny Avenger
3" Exhaust - DP, Cat and Ultra Flo Dyno Max.
and just about every thing else...
except the body looks like hell.
1984 Turbo Coupe
Rebuilt Engine
87' or 88' TC hood
revamp
May 2002
Norristown, PA
I think the tailpipe would look better with a high temp low black gloss paint on it. It would not stand out as much. That's just my opinion though.
88 TC W/ 87K:
K&N in custom sanded airbox||Gillis Valve||Stereo Sytem: Pioneer 8400, Infinity Ref. Series & Polk Audio Speakers Powered by 4 Channel Pioneer Amps||Performance Radiator & Cooling System||Custom Interior Converion||Gutted Cat & Dynamax Ultra Flow Muffler||Indiglo Gauges ||and more to come!
turbocoupe88
Mar 2002
Philly,Pa
You could also just take the tailpipe off but that would make it a littler louder but wont affect performance. When I had my 6cyl I just cut off the part of the tailpipe that was sticking out under the bumper and that hid it pretty well.
Grant
Jul 2002
Thomasville, GA
Is that just a 3" tip?? Why, may I ask? If you have a full 3" exhaust put on, you won't need that anymore [Image: smile.gif]
83 TC : full 3" exhaust, 17" 93 cobra wheels, many mods awaiting install once the engine's back in
85 Turbo Bird
Mar 2002
Sacramento, CA
cut the tailpipe off and put a turn down on there!! that spoiler looks pretty god. [Image: biggrin.gif]
85 TC Auto
250-280 rwhp or Bust!!!!
mods: Sony HU, Pioneer 6.5" 3-way in the door and Pioneer 6x8 2-way in the rear deck; full 3" exhaust installed(dp, hi-flow cat, 3" MAC mustang GT cat-back)
It is a three inch tailpipe. The muffler guy didn't have a 3" tip.
1984 Turbo Coupe
Rebuilt Engine
87' or 88' TC hood
JLockhart
Jan 2002
Dallas, TX
I don't think it looks too bad. I'd cut it off a litte shorter so that it doesn't extend beyond the bumper.
87 TC, T5, t3/t4, alky spray, 3" exhaust. 13.65 @ 102.75 on radials
if you decide to get rid of that tailpipe...id be interested in buying it...is it mandrel bent??
Zach
85 Turbocoupe. 5-speed.
Mods- single 2.5 inch exaust with highflow cat and Apex bullit muffler, Saab 9000 front mount IC,Centerforce II clutch kit, Gillis BV set at 19psi,K&N on VAM, Hurst shorthrow shifter.
BEST ET-(1/8)-9.7 @71.9 mph
Dan E
Greensboro, NC
I have a 3" tip too but it is cut off at an angle. Maybe that would help the look ?
Dan Eaves
Dan Eaves
SacsTC
Jun 2002
Sacramento, CA
I agree with 85 turbo bird. Take that long ext off there and just put a turn-down that is hidden by the bumper so that you don't see it.
