85turbotbird
Mar 2002
Woodbury, MN
My speedometer was sticky when I got the car about a month ago, I've driven it about 1500 miles, and now the speedo sits below 0 when stopped and twitches. If you put and electrical load on the system, it will fluctuate more. It is also inacurate at any speed. any ideas, or experiences would be helpful,
Thanks
Tadd
85 turbo coupe
beats an f-150
gets roasted by a supra
Sometime an erratic speedo is tell tale of charging problems. Had any other signs of inadequate charging?
85turbotbird
Mar 2002
Woodbury, MN
I don't notice any, and I never get a gen light or anything (if there is one). My other gauges have problems (fuel and oil pressure, not sure if the amp gauge works either.)
Tadd
85 turbo coupe
beats an f-150
fordtech58
Apr 2002
Pukalani, HI. U.S.A.
You may have 2 seperate problems but cure may be fairly simple. first suggestion would be to remove the instrument cluster and inspect the wiring connectors to see if they are fully seated and locked in. If your fuel and oil guages are acting erratic you probably have an IVR (instument voltage regulator) concern which is very common. From Ford IVR part # is D1AZ-10804-A list $34.13. From a local parts store the "Standard" brand part # is VRC-606 list $36.80. Though I have never seen it this could be the route cause of your speedo problem also. Your speedo is electronic and the IVR conrols the voltage for the entire cluster. If you still have a speedo problem after the IVR, next likely source would be the vehicle speed sensor mounted on the left rear side of the trans. If the VSS wiring is clean, dry and tight remove the sensor, inspect the drive gear for wear if looks ok sensor probably NG hope this helps Rick B.
85 Elan 5.0 Mine since 86
85 TC 5spd. Wifes toy
86 TC 5spd. 1 owner Calif
86 TC 5spd. pc/rotted
88 TC 5spd. pc/rotted
93 Aerostar family hauler
01 F150 Supercrew towrig
84 RZ350 Yamaha my ride
81 Ltd440 Kawasaki wifes
registry loves us !!!!!
80 Buick Dragcar 440ci Chevy [email protected] (was originally a turbo)
Walsted
Fort Worth, TX
Quote:Originally posted by fordtech58:
...Your speedo is electronic and the IVR conrols the voltage for the entire cluster.
Having spent a lot of time correcting mistakes resulting from my (so-far unsucessful) solid state IVR experiments, I'm pretty sure that the IVR does NOT supply voltage for the speedometer. The IVR supplies voltage for the fuel, oil, and temp gauges, and the fuel relay for the system sentry. The amp gauge is also a separate circuit, at least on the 1986.
So, if it is not a bad connection at the back of the instrument panel, an overall car-wide electrical problem, or a short in the flexible circuit board, I agree that it is probably two separate problems.
Mike Walsted - NATO member
1986 5-speed TurboCoupe with more problems than an Algebra textbook.
