Speedo, door chime, and headlights?
Blade1433 Offline
My speedometer doesn't work. When you turn on the turn signal it clicks up and down, thats all. What could this be? Blown fuse? If so, what number is it?
Also, that door chime is REALLY annoying. How can I unhook it?
Since my head lights don't work, does anyone in Lorain-ish area have a manual they can lend me or scan the pages with wire diagrams?
If not, what would the best manual be? I liked Haynes for the Isuzu, but not sure on the TC.
Thanks,
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy in color
I can probably xerox some pages from the manual in the next couple days. Give me a call Thursday PM or email me
If the speedo moves slightly with changing electrical loads, I would think it is still good. Does the cruise control work? If that also doesnt work, I would look for a bad VSS. You can also run the KOEO codes and look for a VSS code.
Blade1433 Offline
Nope, the cruise control doesn't work.
Blade
