Speed sensor question.....
Thndrchckn420 Offline
What is the part that goes between the speed sensor and the tranny? @ 1.5 inches long spindle lookin thing with a 'wheel' on it? spins inside the speed sensor? ford cant find it.
88 5-spd. bypassed BCS, cleared cat, Gillis valve, no major mods yet.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
AFAIK, you can not buy the VSS rotor seperately, you must buy the whole VSS. The rotor should not come out of the VSS body anyway. Is the "wheel" a colored plastic gear that is secured to the shaftwith a metal clip? That plastic wheel is the speedo / VSS driven gear. It mates to a gear on the output shaft of the tranny.
Thanks, just bought the sensor from ford. figured it out pretty quick.
Ed Meinel Offline
Hey, a part Ford still makes!!
Ed Meinel
88 TC: stock
88 TC: twins!
99 Mustang GT vert: modded
www.turbotbird.com/showroom/EdMl_88TC.html
Ed Meinel
04 Jaguar XK8
01 Bentley Arnage
Gone: 88 TC to son's father-in-law
Gone: 88 TC: twins!
In stock too. And Holy Sh*!....cheaper than advance auto.
Ford still makes / stocks it because it isnt a TC specific part.... same VSS used on lots of Ford cars / trucks. Same reason they still make / keep in stock IRCMs.... same exact part was used in about 2 million Taurus / Sable.
Ed Meinel Offline
You would be surprised what simple things are model-specific. For example:
A4LD -- millions of 'em
console shifter -- millions of 'em
shifter cable -- TC-specific, obsolete
/bangs head on desk/
Ed Meinel
04 Jaguar XK8
01 Bentley Arnage
Gone: 88 TC: twins!
Ed, have you tried Green Sales on the shifter cable?
Ed Meinel Offline
Yup, nothin' there. Their nationwide search turned up a big fat zero, too. I guess Ford thought that the movie quote was, "If you [don't] build it, they will come [buy a new one]."
Ed Meinel
04 Jaguar XK8
01 Bentley Arnage
Gone: 88 TC: twins!
From the movie "Field of Screams"????
