alright i unplugged the o2 sensor two days ago and removed and unplugged the VAM
car drove great...only issue was WOT under 3k which is understandable...but over 3k - the car never pulled so good...the miss went away even when hot
i just cleared the ecm and plugged and put the vam back on but left the o2 off
ice cold it pulled okay but not as strong as with it off...once it got warm it started bucking and stumbling
the CEL would stay off until i got on it then it would stay on until i turned the car off and it would go away until i got on it hard again
heres the codes i got once i got home :
KOEO : 11
CM : 41 "System was lean for 15 seconds or more (no HO2S switching) "
65 "Check intermittent HO2S (signal or ground)"
KOER : 21 "Engine Coolant Temperature (ECT) sensor out of range "
34 - emissions recall
41 - "System lean "
74 - didnt tap brake
77 - i didnt goose
i tested the ect the other day and it came up good...ill test it again now
also how can the o2 possibly be lean if its disconnected...and how can it be intermittent if its disconnected?
-james
87 TurboCoupe - 5spd
[This message has been edited by jabobia (edited 08-18-2003).]
KOEO : 11
41 - "System lean "
77 - i didnt goose
-james
87 Thunderbird TurboCoupe - 2.3T, T5, 3.55L - K&N, 18psi - 16.14@88mph(2.37 60')
88 Thunderbird Sport - 5.0SO, AOD, 2.73L - 16.77@82mph(2.39 60')
www.cardomain.com/id/jabobia
jabobia.com
jabobia.com
