Solved: High idle and stumbling on throttle?
DR1Pilot Offline
[video:youtube]https://www.youtube.com/watch?v=PbZIF-AC_Hg&feature=youtu.be[/video]
I cannot figure out what the problem here is. Idles high and has some pulsing too. Almost sounds like misfire or possibly running on only 3 cylinders? Stumbling under throttle.
A little background, just got done replacing the head gasket and some mild gasket matching. EGR housing cracked so I just deleted it all together.
Started up and ran like crap so I checked for fuel in the rail, set the timing to 10 deg BTC, checked that the header was tight, checked for possible locations of vacuum leaks but I'm not sure beyond checking for cracking or loose hoses where to look.
Any ideas or thoughts? Any aid is appreciated.
Project 88 T-Bird 74k original miles
and a Loud Moped
Check fuel pressure and check for vacuum leaks again. Consider pressurizing the intake to find vac leaks or do a smoke test.
Stock IC? If so, it is easy to not get the turbo to IC hose seated correctly resulting in a bad vac leak.
Are you 100% sure the cam timing is correct? What is the idle vacuum?
DR1Pilot Offline
I was going to do the propane test for checking vacation leaks. My brother suggested it.
As for fuel pressure... not liking the price on those testers. Any diy solution you guys suggest? Found a few online but nothing I can get locally.
and a Loud Moped
Many auto parts stores will loan you a FP gauge for free with a $100 or so fully returnable deposit.
DR1Pilot Offline
Got the car to run a little better. Still idles high even with the TPS set to .95V. Throwing a CEL if left on for a minute so I'm going to try and run a self test
and a Loud Moped
DR1Pilot Offline
Should I be able to blow any air through the Idle Air Controls valve when it is not active?
and a Loud Moped
Be sure to run the complete self test..... KOEO, CM, and KOER.
DR1Pilot Offline
SOLVED! The high idle was related to the TPS being slightly off (over 1V).
The occasional misfire and stumbling on WOT kicks was either the distributor cap and rotor or ignition wires.
Luckily that was the first thing I checked that actually cost me any dough. But at least now the injectors and VAM are clean!
and a Loud Moped
Not B Anymore Offline
Excellent news! Thank you for posting the solution as well.
