turborob
Jan 2007
Surrey BC Canada
I have been searching and reading so much and its all Get a Megasuirt or Tweecer is there any simple way to do the VAM to MASS AIR conversion Thank you all for your input
Joe F
Jul 2002
Hawkins, Texas - USA
Not simple, no. If you don't want aftermarket, then you'll need a way of making the ECM work properly with the MAF, like an EEC-Tuner, a J3 chip and adaptor, etc.
turborob
Jan 2007
Surrey BC Canada
Thank you I have the LB3 ecm what would be the best and cheapest of the J3 or EEC-Tuner and how or who would tune this I have 46lbs injectors 70mm T.B. a tube upper intake and a tube exhaust manifold 3" downpipe exhaust and adjustable fuel pressure reg. FMIC, I want 300hp like my old/but long sold 68 gt fastback 390 S code I really want that torque and hp again, but in a car that can make turns with out rolling over.LOL
Joe F
Jul 2002
Well, first off, did you know that you don't need to go mass air to support your goal? Plenty of guys have made that HP and more on the big VAM.
The problem with using 46lb injectors with no chip/tuner is that your ECM still thinks it has the stock injectors, so you wind up running rich. You can cheat your fuel pressure but I'm not sure how low you can go and still have good fuel atomization. You may very well be better off using your stock injectors and raising the FP instead to get some more fuel in there.
As for tuning, you really need either a wideband O2 sensor with data logging or some time on a dyno to get it right.
HTH
