So after JeffK mentioned running NGK 2238's I went out and bought 8 to replace my older Autolite 104's in the 88. Thinking 8 right, well I took 4 of the best that lined up in the chamber best and also side gapped them after reading about it over on TurboFord. I cut the arm back to even with the edge of the center electrode and gapped them to .028. I spent some time online researching this side gapped thing as I have not heard of it before and it seems that many people running it like that feel it gives more power. Well, I must say, it does feel like it has more power to her. Took her out for a ride tonight and it pulls harder than before. Maybe just me wanting it to work, but damn, it sure feels stronger for maybe 20 minutes of work to cut, file, and gap. Thought I would pass along my thoughts. Anyone else do it on theirs here?
Never heard of it, got any good links or articles on side gapping?
I can personally attest to too wide a gap and spark blowout.
Here is one I read while researching it. http://performanceunlimited.com/document...pping.html
I used a cutoff wheel nice and easy doing the cutting, filed the end smooth with a small file, gapped them , and installed.
Never heard of sidecutting. Does sound interesting. Thanks for the link.
I remember reading articles long ago about indexing the plugs but I don't remember the direction? Down to the piston with the open plug or towards the head chamber?
I indexed mine as well, I simply bought 8 plugs and found the four that were best. You want the opening of the plugs to face either the intake or the exhaust valve. Most forums online say that favoring the exhaust is best, but to me just facing them towards the interior of the chambers works. You can see in my pic that one is facing out, and the other facing towards the inside. You can make a sharpie mark on the ceramic part of the plug to be able to see which way they face when installed, basically if the gap faces the inside, it's good enough.
The concept makes sense, like a van degraph growing an arc. Seems like electrode life can only be worse though, and why are there not any performance plugs made like that then..??
(05-23-2020, 12:56 PM)RC Martin Wrote: The concept makes sense, like a van degraph growing an arc. Seems like electrode life can only be worse though, and why are there not any performance plugs made like that then..??
That’s a very good point.
While I agree that it sounds like a great concept and seems to make a lot of sense, why aren’t performance plugs made like that?
I used SplitFire plugs for years until they stopped making them, likely because the sales dropped as our Turbo Coupes slowly started disappearing from the roads. I thought they produced more power and all that comes with that (more horsepower, better fuel economy, easier starting, etc.) I still have a couple of sets with some life left.
For those unfamiliar with the concept, the side electrode was split into two parts over the center electrode, hence the name SPLIT Fire. It looked like the letter Y. But even these weren’t true side-gapped plugs, the center electrode was just more exposed to the combustion chamber than traditional ones.
Other than the eventual wear on the center electrode I can’t think of a good reason.
So, after posting the above comment, I decided to do an Internet search for side gapped plugs. I found quite a few pages on how to do it, etc., but I didn’t see one where they are offered that way for sale.
I did find this page ; what I found interesting were the replies in the Comments section—generally not positive, at least not for everyday use.
