Should i be able to burnout?
Spooledyou Offline
I have an 87 TC and i have never spun the tires on it besides when i have been in gravel a couple times. I have seen tons of pics of TC's roasting the tires. Do you have to "drop" the clutch in order to do a burnout or should i be able to do it by just giving it some high rpm's and releasing the clutch quickly but neccesarily dropping it?.... My car's turbo boosts pleanty of psi....
Just do it!
jabobia Offline
you should be able to smoke them...if you twist it up to like 4k and dump it(just let it out quick) and then start laying into the brake a lil to stop you from rolling you should be able to smoke them nice in 1st...itll be murder on a stock clutch though
if its dry ill just dump it and wont brake at all...leaves two nice marks a lil smoke and alot of noise
if its a lil wet i can rev it to 3k and dump it hard and itll spin in 1st...then i just lay on the brake and watch the show [Image: biggrin.gif]
i havent tried hitting 2nd while burning though
then again it all depends on your tires...mine make alot of noise but it takes a bit to make them smoke
the tires on my tbird sport on the other hand, make it look like a monster when i burnout - smokes with just a few revs of the tires and makes LOTS of smoke
-james
87 TurboCoupe - 5spd
www.cardomain.com/id/jabobia
jabobia.com
Turbobob_dup1 Offline
You don't find that touching the brakes kicks in the ABS? I find that mine does.
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in fender,gutted upper/knifed lower,big valve head,A237 cam ,60mm throttle body,Talon 1G BPV.
4 + 1 = 8!!
mustangtyy Offline
Tires do alot for spin and sound. My old tires I would spin easy with no sound. Got some new ties and better tration , but more sound. Ty
87 TC with 190,000. Gillis valve, K&N on VAM, Home made "Ram" air, Sac Mustang DP to a 3" Dyno Max Super Turbo dumped before rear axle, Ported E6, Paxton AFPR, GN FMIC, RR Cam, T3 at 20 psi, OBX BOV, Spec Stage III Clutch.
Speeds8erM-1 Offline
The "sound" you are hearing is the tires trying to hook, street tires that try to hook, usually make a good bit of noise.
cashsaudio Offline
I've went 15mph in first and then decided to just punch it and my tires just roasted. I have no idea what i did to my car but everything was stock. Well you can dump the clutch on a stock clutch but don't be planning on doin it daily. Jeff
deadbird Offline
I have never been able to keep the tires spinnin going thru the gears unless i was on wet pavement or gravel. but i like to do it on freshly resurfaced roads or coated ones. Smoking can also depend on the pavement. if you get pavement that has the black tar coating that smokes good. and doughnuts easily. BUT as far as anyone knows i never beat on my cars.
1987 5 sp.
- 4.6 2v swap.
Glenn 88TC Offline
I dump the clutch in 2nd gear at the track to do the burnout. Street tires I can roast like it was on ice.
Just do it!!
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, TE60 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
jabobia Offline
as far as kicking in the abs...i dunno...my abs light is on so i guess it doesnt work [Image: rolleyes.gif]
-james
jabobia.com
