TheBullMoose
Nov 2020
Norfolk, Virginia
Howdy!
I'm looking for recommendations for OEM equivalent Shocks, Struts and Springs for an '84 turbocoupe that I'm trying to get back on the ground/road. I've seen plenty of shocks available but no struts. Are there any exchangeable parts from other foxbodies that would fit the bill?
Thank you!
John B
Dec 2015
New Jersey
I know there are various struts available for the 87-88s. Not sure if they are the same or not. I don't see why they would be different but hopefully someone can chime in with experience on this.
88Slowbird
May 2019
Tampa, FL
(10-22-2024, 02:04 AM)TheBullMoose Wrote: Howdy!
Thank you!
no one produces struts for the 83-86 cars anymore
I have an 85 and figured out I can use 87-88 struts if I use 87-88 strut mounts
here's the part #'s I used:
Monroe 71803 Struts (they come with metal spacers but they're not needed with 83-86 spindles)
Monroe 901974 Strut Mounts
1985 TC 5 Speed: Steeda Tri-Ax Shifter, Big R Stage 1 T3, Stinger FMIC
TheBullMoose
Nov 2020
Norfolk, Virginia
(10-24-2024, 08:16 PM)88Slowbird Wrote: (10-22-2024, 02:04 AM)TheBullMoose Wrote: Howdy!
Thank you!
Thank you! I'll have to pick those up! Did you have to do any mods or fabrication or was it just bolt up?
88Slowbird
May 2019
Tampa, FL
(10-25-2024, 02:51 AM)TheBullMoose Wrote: (10-24-2024, 08:16 PM)88Slowbird Wrote: (10-22-2024, 02:04 AM)TheBullMoose Wrote: Howdy!
Thank you!
they bolted right up no issues
