Asimov
Jan 2005
East Tennessee, US
May be totally off here, but the way it sounds, it could be that somebody put gear oil in the transmission instead of ATF.... Just a thought, you said you checked the fluid... what kind of fluid was it?
[Edit: oops, just reread this thread and noticed it had already been mentioned, sorry]
-asi
1986 TC, 132k pretty well taken care of miles. k&n, gillis@17, timing set at 12.5 (spout out), A/C delete. Very restrictive exhaust at the moment [email pics to asimov at forced-induction org for sales/id purposes (free hosting)]
[This message has been edited by Asimov (edited 02-18-2005).]
-asi
1986 TC, 132k pretty well taken care of miles. k&n, gillis@16, timing @ 12 (spout out), A/C delete. 3" Downpipe (no other exhaust... Whoever described that sound as a "pissed off tractor" hit the nail on the head)
[email pics to asimov at forced-induction org for sales/id/showoff purposes (free hosting)]
Ryan H
Oct 2004
Panama City, FL
Yes, I've actually changed the fluid twice, because it indeed did have gear oil in it. I changed it the first time with cheap Super Tech ATF and it made the gears quiet down a bit, then changed it again a few hundred miles later with Mobil 1. It got a little smoother and quieter, but the tranny still needs to be replaced. This isn't even worth rebuilding in my opinion because JY Mustang T-5's are so abundant in my area.
2birdsinthefalls887
Feb 2002
Beacon Falls,Ct.
Ryan,
Beware, the 5.0 Mustang uses a different trans than our cars, find one from a 4- banger Mustang.
Just my 2 cents worth.
87 T/C,base, 5spd, bright red metalic, 136,000 miles. My pride and joy of the fleet.
88 Turbo Coupe,loaded 104,000,
88 Turbo Coupe,Fully loaded,
Been to Carlisle 2002,2003, 2004,2005,2006,2007
And damn proud to be a NATO member!
Nate K
Eastern Shore of Virginia
Ryan, few years back I was having shifting problems and Jeff K. recommended that I try changing the fluid PLUS adding in a 4 oz. bottle of Friction Modifier. Took care of the problem and that's been two years or more. Seems to be common practice with alot of racers and gearheads. Give it a try.
NATO Member
3 - 88 TURBOCOUPES www.turbotbird.com/showroom/nk_88tc.html
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
93 F150 Flareside Mark III Custom 5.0L
Asimov
Jan 2005
East Tennessee, US
Quote:Originally posted by 2birdsinthefalls887:
Ryan,
No offense, but the 5.0 5 speed's only difference from the 4 speed is the pilot bearing -- you can either do a bit of machine work on the 4 speed pilot bearing (I believe it's the one with the smaller hole), or you can change input shafts -- I've even read that the 4 cyl 5 speed input shaft is STRONGER than the v8's -- dunno if that's true or not, hopefully somebody will speak up and set us both straight
-asi
2birdsinthefalls887
Feb 2002
Beacon Falls,Ct.
our cars transmissions have alot lower 1st gear than the 5.0, to get the big car with the 4 cyl. going from a stop. I have heard that 5th is a different ratio also.
teal95
Dec 2002
Grass Lake, MI
He was referring to that it bolts right in with the exception of the pilot bushing. I have a 5.0 T5 in my '88 TC with 4.10 gears.
steve
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
