Phillieb
Dec 2010
new york
Hi Guys , Can someone describe to me how to go about changing the shifter handle on my 5 speed turbo coupe? Mine is wearing out and I would like to change it. Please if you can I need step by step describtion. Thanks Philb
Philip Boccabella Burgundy car 5 speed 1988 Ford Thunderbird Turbo Coupe 2.3 liter. Water/meth system. Recently eliminated the cat converter and added flow master mufflers and 3"pipes.55,000mi./1988 T/C-Black T3 garret new paint in 2018
natmac3
Mar 2002
Aberdeen, MD
Not B Anymore
Nokesville, VA, USA
[color:#FF0000] [size:14pt]Nate:[/size][/color]
Phillieb Wrote:...on my 5 speed turbo coupe? :dunno:
"phillieb" - If you mean just the knob, just turn it counter-clockwise. It's just screwed on to the threaded shaft.
goldwing
Aug 2009
North Carolina
11-16-2013, 09:04 AM
(This post was last modified: 11-16-2013, 09:07 AM by goldwing.)
The entire shifter should just be held in by 4 bolts. Its as easy as taking it out, pouring a little trans fluid on the end of the new shifter then installing back in the shifter linkage (usually a hole)...you'll see it inside the trans.
If you're talking about replacing the shift handle (stick part) thats just two bolts. The factory stick has a rubber isolator that off sets the handle toward the driver. I don't like it because if you notice the handle rubs the floor board boot which in time will cause a hole. I elect for the shorter after market stick from "Pro-5.0". They bolt on without the rubber isolator so the stick doesn't rub the floor board boot. They're sold for Mustang T5 trannys but will work on our Tbirds. They're only $25 on ebay.
T.C:87 5 speed
natmac3
Mar 2002
Aberdeen, MD
B Wrote:[color:#FF0000][size:14pt]Nate:[/size][/color]
holy moly! i'd almost swear that wasnt there when i read it the 1st time...who edited it in when i wasnt lookin... lol
1987tc
