Shifter buzzing
fiveliter8 Offline
My 88 TC has a "buzzing" feel in the shifter at certain RPM's, any gear. It's slightly audible too. Should I start hunting for another trans? [Image: frown.gif] Shifts fine otherwise.
www.stangnut.com
1988Tcoupe-ye will be missed
'09 Flex SEL
1984 20th Anniversary GT350 Mustang 'Vert
1984 Mustang GT T-roof
1965 Shelby Cobra Replica
Resurectedbird Offline
could come from any number of different drive line places. I would say check your trans mount and for anything else loose.
Currently birdless, but will get another someday!
88turbo Offline
What shift knob do you have? When I had the stock one in my '86, it buzzed really loud when passing 4K rpms! Switched it out with a black 8 ball style knob and it's nice and quiet now.
crystal Offline
My 87 does that as well. It vibrates bad enough at higher rpms that if I hold on to it, I start to feel sick.
I can also hear a buzzing and it turned out to be the shifter boot. If I press on the bottom drivers side of the boot the buzzing stops.
88 TC, 63 Ranchero, most of a 48 Prefect Wink
Check crossmember to frame bushings for wear. If they rot away, and crossmember makes metal to metal contact with the frame rail, it makes one hell of a buzzing noise.
