phantom
Jan 2005
RAF Lakenheath, England
got the new head on, and cam installed.......shawn came by today, and we got it running......only one issue however.....it runs, but after about a minute or tow, it stumbles and shuts off.....no check lights come on, and no codes come up with the koeo test......anyone have a similar issue after replacing a cylander head??? also, the cam timing looks to be off by one tooth....is this enough to cause that proble?
left right left...the perfect shift...maybe i should call cadience when i bang the gears....
The cam being off a tooth is a problem but I don't think that is why it is shutting off.
Can you keep it going if you give it some gas.
How big a cam did you put in it?
Run fuel system diagnostics
phantom
Jan 2005
well, the cam timing is 1 tooth off, the cam i got is a motorsport a234.....also, the ignition timing is 3* degrees off(10*)....but the car will keep running if i give it some gas. i think the stator might have gone bad....
Matt S
Mountlake Terrace, WA
Yes mine died after doing the head when the cam was off a tooth, and I had a stock cam.
Sold it *
phantom
Jan 2005
ok, well ill fix that this weekend.....no big deal....i cut the timing belt cover so that i could still have the timing markers showing on the crank, but can see my cam gear for when i get the adjustable gear that i know ill need
Well, if i beat you when i was stock, what would happen now?
