COOKER
Jan 2002
Canton, Ohio USA
Iknow that there is an article in the faq but when i printed them off it sounded easy and when i got to the car it is like what is this!!!! I CAN"T SEE ANY THING, like where the wrench goes and, and the screw driver. so any help will help uot alot
thanks guy's i know you will come throught for a 88 tc in dier need of help!!!!!
DAVE COOK
NEED MY TC BACK
Lean over the engine from the driver's side with a good light. Look behind the throttle body. look where the round cylinder ends about the middle of the TC. Now look a little lower and you should see most of the TPS. It's held in position by two small phillpis head screws that face straight at the fire wall. You will need a short small phillips to loosen them just a little. Just follow the instructions in the article from here.
segfaultxr7
Aug 2001
Cape Coral, FL
The TPS is kind of hidden under the idle air control valve (the cylinder-shaped thing). You'll have to take it off to get access to the TPS. Be sure to have another IAC gasket on hand (I use high-tack sealer too, that might be overkill though), they're easy to break and then you'll have a nasty vacuum/boost leak.
The TPS is mounted to the throttle plate shaft. You can see where it pivots on the front of the throttle body by manually moving the throttle bracket. The TPS is mounted across from that spot. You'll need a short screwdriver to loosen its screws since it is pretty close to the firewall. Good luck!
88 TC 5-speed
Good luck [Image: biggrin.gif] Setting the tps is a pain, even ford could not get it rite on my car!
1988 Turbo Coupe
2.5" Stainless exhaust. Duals with flowmasters.
House of Kolor paint by: Glen Gordon
ROH Wheels
Lowered
Front Mount IC
Turbo Smart BOV
Gillis Boost valve
K&N
I don't remove the IAC to set mine. I also make new IAC gaskets from cardboard. Cereal box cardboard works just fine - thanks GT
