I just got finished installing the Thundercats Sequential Turn Signals that I got from Gary S. in Carlisle.
After re-reading the (somewhat unclear) instructions 5 times I finally found better instructions on line then figured the wiring out LOL !
They are pretty cool ! The Hazard Lights even flash from inner to outer on both side which is neat !
The only issue is that the "Rear Lamp Out" idiot light does flash when the signal lights do...but no big deal...I'll pull out that bulb...
You do have to replace the Inner Parking Lamp Fixtures with the ones supplied and have to open up the fixture hole in the plastic housings...but that wasn't too bad.
I figure these are good for 10-15 RWHP at least LMAO !
Dan Eaves
Dan Eaves
Dan Eaves
