miamihawk
Feb 2002
Fredericksburg, Va
What is the little round thing that has a two wire connector and a rubber house. It is located just below the VAM bracket on the fender well?
Fender Well KN Flter, 255 HiPressure Fuel Pump, Full 3" Exhaust DP to tip with no cat, Magnaflow Muffler
rich
Dec 2002
tampa, FL USA
Hey, sounds to me like you are talking about the boost control solenoid. 2 vacs and an electrical?
2.3L Turbo in 88 stang, browntops, 93 a4ld, volvo ic, broncoII rad, gillis valve set @15, k&n af.
miamihawk
Feb 2002
Fredericksburg, Va
nope, i dont think so..its one vac and an electrical..its round about 3 inches across
Walsted
Fort Worth, TX
Maybe a broken BCS? Does the vacuum line run to the vicinity of the turbo? Made of plastic? Perhaps yours has a spot where the other plastic nipple broke off?
Hope this helps
Mike Walsted - NATO member
miamihawk
Feb 2002
Fredericksburg, Va
heh all..if you like at this picture it is right where jonathon has put his giggle gas controller at..you know that big purple doohickey. i think he must have relocated or removed the sensor i am talking about in order to mount that.
look here
http://www.geocities.com/allaboutzex/
Kev
Harrison Arkansas
Kev
Yeah, that's exactly where the boost control solenoid is, right where that purple thing is mounted.
Kev
1988 TC 5spd
