Sensor Question
miamihawk Offline
What is the little round thing that has a two wire connector and a rubber house. It is located just below the VAM bracket on the fender well?
Fender Well KN Flter, 255 HiPressure Fuel Pump, Full 3" Exhaust DP to tip with no cat, Magnaflow Muffler
rich Offline
Hey, sounds to me like you are talking about the boost control solenoid. 2 vacs and an electrical?
2.3L Turbo in 88 stang, browntops, 93 a4ld, volvo ic, broncoII rad, gillis valve set @15, k&n af.
miamihawk Offline
nope, i dont think so..its one vac and an electrical..its round about 3 inches across
Walsted Offline
Maybe a broken BCS? Does the vacuum line run to the vicinity of the turbo? Made of plastic? Perhaps yours has a spot where the other plastic nipple broke off?
Hope this helps
Mike Walsted - NATO member
Mike Walsted - Sold my 1986 5-speed TurboCoupe
miamihawk Offline
heh all..if you like at this picture it is right where jonathon has put his giggle gas controller at..you know that big purple doohickey. i think he must have relocated or removed the sensor i am talking about in order to mount that.
look here
http://www.geocities.com/allaboutzex/
Kev Offline
Yeah, that's exactly where the boost control solenoid is, right where that purple thing is mounted.
Kev
1988 TC 5spd
