svo_thunderchicken
Jul 2005
Kingsport, TN.
84 5 speed.. geting a ranger roller and a fresh 8.8 rear end... which gear should i put in it? 3.73 or 4.10... be a weekend car, but do some driving at aorund 70 mph at times....
RDOG
Jun 2001
Ontario. California U.S.A.
IMO, I would go with 3.73's. I tried 4.10 and hated it on the freeway. Thats just my 2 cents
Glenn 88TC
Lebanon, PA
I would stick with the 3.55's
NO TC and NO headaches.
Thndrchckn420
Mar 2003
Winchester, VA
I second that. I love my 3.55s. Had the 3.73 in the last TC, and there was no reason to use 1st gear. I have the 4.11s in my E-350 Pwrstroke, and the engine isnt under enough load to make the turbo worth having. Just my $0.02.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
svo_thunderchicken
Jul 2005
Kingsport, TN.
3.55 it is :-) thanks boys... :-) is the 7.5 stock to 8.8 with disc brakes swap going to be worth it? hehe or should i keep the lighter weight 7.5/// and transfer the brake parts over. :-)
[This message has been edited by svo_thunderchicken (edited 10-25-2005).]
martin0660
Jun 2002
Greensburg, PA
I beleive your 84 should have a 3:45 gear in it now, if you want more, a 3:55 isnt going to make much of a difference. That said, I really like the 3:55 for a daily driver. I had a 4:10 in my old silver TC and regretted doing it.
I personally dont think the TC disk set-up is really worth the effort.
Bob Myers
Matt S
Mountlake Terrace, WA
Yeah wish I had 3.55's since all I do is drive on the highway. Dare I say 3.45's?? I really need to learn to work on rear ends so I don't have to pay someone 300 bucks to swap gears.
Sold it  *
Reeve
Jan 2004
Grants Pass OR
It is not much work to put in the disc rear. Just get a 5 spd 3.54 disc 8.8 complete and bolt it in. The discs work just fine without any other change to the brake system. I have been involved with two such swaps and in both cases (78 fairmont power brakes and 80 Capri manual brakes) it has worked perfect. I don't know if you will need to adapt the brake line but I think it will take an adapter. Mine required a brass fitting from autozone and a short piece of hard line.
1988 TC IHI POWER [email protected]
1980 Capri RS turbo EFI [email protected]
1988 RX-7 Turbo II
1988 TC stock for now
1980 Capri RS turbo 11.42@120 broken
svo_thunderchicken
Jul 2005
Kingsport, TN.
well im geting a rear end this weekend, either im going to use it in my bird, or he has a project car he will use it in... complete with brakes...
Thndrchckn420
Mar 2003
Winchester, VA
Id use the 8.8.
