John B
Dec 2015
New Jersey
Going to replace the water pump, thermostat housing, and thermostat this weekend. The housing and water pump came with paper gaskets. What's the general consensus on using a small amount of sealant (Permatex water pump sealant) with the gaskets versus gaskets alone?
gtbird
Dec 2001
Hope, RI 02831
(11-17-2020, 04:43 PM)John B Wrote: Going to replace the water pump, thermostat housing, and thermostat this weekend. The housing and water pump came with paper gaskets. What's the general consensus on using a small amount of sealant (Permatex water pump sealant) with the gaskets versus gaskets alone?
I would recommend a small amount of Permatex.
I always put a THIN layer of Permatex Ultra Black on any paper gaskets (both sides of the gasket). Been doing this for many years with zero leaks or seeps.
anasazi4st
Feb 2015
Phoenix, AZ
(11-17-2020, 11:31 PM)Jeff K Wrote: I always put a THIN layer of Permatex Ultra Black on any paper gaskets (both sides of the gasket). Been doing this for many years with zero leaks or seeps.
Yeah, I used to use Permatex Indian Head gasket shellac (because that’s what my Dad used in the 60s and what I was taught), but that was a real mess and involved scraping it off each time. Ugh.
