When replacing a shaft seal (crank, cam, aux, whatever) is it necessary to lubricate the outside of the seal (the part that rides against the whole, not the inside with the double lip)?
I just installed a new crank seal (front) and forgot to lube the outside of the seal. I did grease the inside double lip, however.
A.K.A. Corey Bennett
