87turbotbirdmatt
Mar 2005
Sarasota, Florida USA
I saw that Advance (Discount) Auto Parts has a 150 amp high output alternator for the 87TC as an OEM replacement from powermaster. Anyone know if this requires the same mods to the bracket as a 3G upgrade?
Should I just go for the 3G and do the mod, or is it the same item that just bolts on like stock?
_ _ ___________ _ _
87TC: K&N,
Bullet Exhaust - Gillis Valve, IHI @18PSI
Is it a one wire alt? If so, stay away.
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 21 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 04 Taurus Duratec (wifes car)
karnage
Mar 2003
Olympia, WA.
Yeah stay away from the one wire alts.You'll end up cooking the battery since there isn't really any voltage sensing.Get a good 3G alt from pa-performance.com
84 TC with 88 hood LA-3 full 3" exhaust Rods header ported/polished big valve head schneider roller cam RW adj cam gear Kirban gillis at 20 # boost MSD ignition 255 lph Walbro full gauges
17 inch centerlines 944 front mount IC 80mm MAF
65mm tb-rotated intake on the way to 400HP
87turbotbirdmatt
Mar 2005
Does running a gel cell make one bit of difference?
___________________
87TC: K&N, Bullet Exhaust - IHI @17PSI
_ _ ___________ _ _
87TC: K&N,
No. One wire alts regulate alternator out voltage only, not electrical system voltage, and the 2 can be different depending on system load, resistance in connections, etc. Not to mention that they dont start to charge on a fresh start until they hit the excitation RPM, which can be fairly high, depending on pulley sizes, ratios.
87turbotbirdmatt
Mar 2005
Thanks for the input. I'll go with the 3G alternator.
___________________
_ _ ___________ _ _
87TC: K&N,
