Saw High output Alternator for 87TC from Powermaster...better to go with 3G?
87turbotbirdmatt Offline
I saw that Advance (Discount) Auto Parts has a 150 amp high output alternator for the 87TC as an OEM replacement from powermaster. Anyone know if this requires the same mods to the bracket as a 3G upgrade?
Should I just go for the 3G and do the mod, or is it the same item that just bolts on like stock?
_ _ ___________ _ _
87TC: K&N,
Bullet Exhaust - Gillis Valve, IHI @18PSI
Is it a one wire alt? If so, stay away.
karnage Offline
Yeah stay away from the one wire alts.You'll end up cooking the battery since there isn't really any voltage sensing.Get a good 3G alt from pa-performance.com
Does running a gel cell make one bit of difference?
___________________
87TC: K&N, Bullet Exhaust - IHI @17PSI
_ _ ___________ _ _
87TC: K&N,
No. One wire alts regulate alternator out voltage only, not electrical system voltage, and the 2 can be different depending on system load, resistance in connections, etc. Not to mention that they dont start to charge on a fresh start until they hit the excitation RPM, which can be fairly high, depending on pulley sizes, ratios.
Thanks for the input. I'll go with the 3G alternator.
___________________
_ _ ___________ _ _
87TC: K&N,
