rusted
black88tc Offline
Ok as i was pulling my motor apart. I noticed a spot of rust about 12 inches long and about5 inched high under the brake booster. And after looking quite hard.i found that it's rusted almost all the way through.
Is it easy to fix without taking the brake stuff off or just to take it off to repair it. The motor is coming out anyway to get rebuilt anyway.
tps87turbo Offline
I would pull the break parts so you have a clear space to grind down the rust & repair it. More space = an easier job.
Tony Sceia -
HERS - Blue 87 TC, fully loaded with every option, Gilies Valve, K & N Filter, 3-core Radiator, New Paint...just needs to be put back together, Interior re-done & get some exterior parts.
Tony Sceia -
HIS Red 88 TC
Jeff K Online
Agreed.
John R Offline
If your pulling the motor It only makes sense to pull the rest , it will just make an easier fix
PetzJC Offline
Even though you have to pretty much stand on your head to get at a couple of the brake booster nuts under the dash, it would make life a lot easier completing the rust repair....
88 Silver T/C, original owner, 264,600 miles.
Loaded with everything except leather & auto trans.
Short block & turbo original/untouched.
Spec-II/III combo clutch assembly.
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16's.
Jeff K Online
Pulling the driver seat out makes it easier to get at the MC bolts, but it is still a MAJOR PITA. Lots of long extensions, U joints, etc make it a little easier.
martin0660 Offline
This is what is going on with my car as well, assuming its alongs the frame rail side of the shock tower. I also suggest you take a good look at the same place on the passenger side, as mine was worse there, assuming because of the turbo heat.
If you dont get it fixed right, the shock towers will pull in and cause all kinds of havock with alignment settings. This is why I am probably going to end up parting my car [Image: frown.gif]
Bob Myers
black88tc Offline
well my passenger side is fine. well i guess i will just pull the brake stuff while i'm at it. so thanks guys for the help
Check the area under the battery tray back to the stru tower while your at it.
black88tc Offline
i already checked under there because the battery is getting relocated to the trunk. so thanks anyways.
