boosted85
Sep 2008
Omaha NE
I'm tlrunnin 23ish lbs stock timing and it will ping in 4 the under wot. The thing I don't get is that it has been around 32 degrees here So I can't see why plus I run it on 93 but its ethanol is there a big difference in non ethanol 91
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
jangus
May 2008
Nebraska
What is your fuel pressure in 4th gear when the pinging happens? Any idea of the A/F ratio when it happens?
Until you can answer those questions you're pretty much running in circles.
88TC 5speed, 160,000+, ranger roller, Evergreen T3, cone filter, manual boost controller.
One parts car still waiting to be taken apart.
Waiting in the garage: SC throttle body, SC intercooler, graphic equalizer, among other things.
boosted85
Sep 2008
Omaha NE
I'm getting a wideband soon any ideas on a cheap but good brand
SHOcoupe
Aug 2009
New Jersey
Glowshift makes some cheap (price) but good quality gauges. Their widebands are probably the cheapest on the market (don't hold me to that), but they work great. I have all glowshift gauges and I know several people who run them now.
88 TC, FMIC, GT35-1 .70 A/R, 42lb Injectors, MS2 p&p, Custom upper manifold, junk heap Stinger header, 3 inch exhaust, Accufab FPR, Bo-Port 1.9 cam, Oversized valves, ported head, Stage 3 clutch, 22psi.
4cammer72
Jul 2005
swansea, sc ,usa
bang4thebuck
Jul 2004
pennsville NJ
AEM kit on ebay is a great deal. I ran one in my old car and never had a problem. AEM is way easier to hook up than a LC-1 kit.
1987 TC 5 speed. To date: AGP 50 trim T3/T4 .63 stage 2 turbo, Ebay bov, 28psi, 255hp pump, Kirban FPR, Ebay Front mount, Full 3 inch Exhaust, Ported Bob's Log, Megasquirt, 55lb. injectors, boport 1.5 cam, boxed lower control arms, Methanol Kit, Ram HD Clutch, front lowered 1/2 inch and E.T. Streets for the track. Best so far 12.5 at 110.8. still tuning.
I'm using this... it looks cool also. However if you ever plan on tuning the EEC you will probably be better off with the LC-1 (ill update when i know for sure whether i can use the ACT input for logging)
http://prosportgauges.com/wideband_AFR_Gauge.aspx
-88 TC Black
-97 Pathfinder
boosted85
Sep 2008
Omaha NE
I just got a lc1 sensor and controller I just need a gauge
boosted85
Sep 2008
Omaha NE
RDOG
Jun 2001
Ontario. California U.S.A.
Get the complete AEM wide kit from ebay. I bought a new one for $145. I used the bing discount(Dont now if they still have that) and it works great. Easy to install even for a non-electrical dork like myself. Look up AEM Gauge Type 6-in-1 Wideband Uego Controller 30-4100. They are now $167 shipped.
