Turbobob_dup1
May 2003
Fredericton,N.B.,Canada
Well like I said it runs better now (not sputtering near as much) but when I go to get in the boost it doesn't feel like it's all there.
I have a T3/T4 style turbo from Precision and it's giving boost but the car isn't pulling like it should. There is a poppng at around 4500rpm and it trys to die. Come off the throttle and it's OK.
My cam timing is at 0 and I'm pretty sure the timing is where it's supposed to be(10-13).
It'll cruise with no prob at all,but give throttle and it bucks.
Any body got any help or ideas?
More Boost!!
'87 turbocoupe almost done!
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in fender,gutted upper/knifed lower,big valve head,A237 cam ,60mm throttle body,Talon 1G BPV.
4 + 1 = 8!!
What kind of fuel delievery components do you have, Kind? age? Have you checked th efuel system?
Turbobob_dup1
May 2003
Pete I have a Walbro 255lph pump , 35lb injectors , Aeromotive AFPR.
The injectors are origional the pump is new and the AFPR is one year old.
More Boost!!
4 + 1 = 8!!
Dan E
Greensboro, NC
Plug Wires, Plugs, Plug Gap, Rotor / Dist Cap Corrosion, Coil ?????
Just some other ideas.
Dan Eaves
Dan Eaves
Turbobob_dup1
May 2003
The coils the only originioal part there. But they're pretty good for life I think. Never heard of one going bad.
More Boost!!
'87 turbocoupe finally done!! Pics soon.
4 + 1 = 8!!
Walsted
Fort Worth, TX
Isn't this the point where someone is supposed to say "Check the hoses to and from the intercooler to see if they have cracks or are folded under?"
Just wondering
Mike Walsted - NATO member
Check the hoses to and from the intercooler to see if they have cracks or are folded under.
Make sure the clamps are properly located and tight also.
Did I get it right Mike? [Image: biggrin.gif]
Walsted
Fort Worth, TX
Quote:Originally posted by Pete D:
Check the hoses to and from the intercooler to see if they have cracks or are folded under....Did I get it right Mike? [Image: biggrin.gif]
I think so, and it comes across as a lot more credible coming from someone who actually has an intercooler.
