Running at the track...
Noname
Guest
Well, after getting a couple mods on, I'm thinking about going to the track to get a E.T. My question is, will it cause any damage to my TC if you run the turbo that long? It seems like if run at like 17/18 psi with the stock turbo, it would run hot as hell. Do you think it would cause any damage?
1988 TurboCoupe - 5 Speed
6" K&N, Gillis Valve @ 17 psi, Centerforce Dual Friction Clutch, Autometer Boost/Vac & Air/Fuel Gauges
It should not hurt a thing. At most the turbo will only be working for around 15 seconds assuming your talking the 1/4 drag strip and not the Salt Flats.
