*open loop*
ok guys, the car stumbles and will ocasionaly shut off while it is on open loop untill the car warms up, then it runs and idles fine. Does anyone have a cluse as to what may be causing this? Stuck injector? Running too rich? Vac Leak? When i looked up under the car, i noticed that my radiator bottom whose had a small pin hole in it, so i will be replacing that tomorrow, but in the mean time im at a loss...could the timing be set too low? any help is appreciated...
[This message has been edited by phantom (edited 05-03-2005).]
left right left...the perfect shift...maybe i should call cadience when i bang the gears....
