John B
Dec 2015
New Jersey
01-05-2022, 08:14 PM
(This post was last modified: 01-05-2022, 08:14 PM by John B.)
Has anyone installed a ron francis engine harness in their 87/88 TC? I really want to clean up the engine bay. My 88 is on a Pimpx, ride control is gone, and car has been converted to vacuum assist (no ABS). I believe the batch fire harness sold through Stinger would be pretty plug and play at this point. Any thoughts? Anything I'm potentially missing that would be an issue?
Kuch
Sep 2016
Manlius, NY USA
John,
That is a great idea on swapping harness to clean things up a little, I also installed a PimpX in my 88 and found that Shannon at Stinger is very helpful with questions. I would shoot him an email asking your same question to see what he says. But being a plug and play harness, it should all you need to run, as far as the extra stuff, I'm not sure on that though.
John B
Dec 2015
New Jersey
(01-09-2022, 12:20 PM)Kuch Wrote: John,
Thank you Kuch, I do have a thread going on Stinger's website too. According to Stinger, the harness has everything in the sense that it doesn't require any external components to run. It also includes relays that would effectively replace the IRCM. I'm not sure when I will do this project but I'll be sure to comment on my experience here.
