Roll call for people running wider tires on stock wheels
Ryan H Offline
I've done a lot of research and I have gotten mixed reviews on running 245 tread width tires on stock 16" snowflakes. I haven't read anything bad about going to a 235 55 16 however. Now that I'm ready to use my employee discount, what size tires are you guys running on your snowflakes? I have had more than a handful of people report crappier handling with the 245 tread width.
I'm kind of torn right now between the Potenza G009 or the BFG G-Force Sport. I'm open to other suggestions as well! I'm kind of set on going with the 235 55 16, but I can be swayed. Let's hear what everyone is currently running?
AerobirdMotorsports Offline
Banned
old raven has Toyo Proxes 245's on his car.
I had 255's on 10-holes on the 83 and 255's on the snowflakes on my old 87 way back when and 255's on the back of the Code 33 Silver-Blue car (all rear only). The 87 didn't handle to well in the twisties (225 front/255 rear Goodyear RSA Z's) but it had great straight-line handling. Layla's got 225/60/16 Toyo's on all 4's and she sticks like glue! Spend your $$ on a better quality before a bigger size. The 255's on the 83 suck (Les Schwab specials).
trashline Offline
i have 245s all the way around, an this thing is as tight as a bulls a$$. I love going fast around turns. I dont have any problems except the wear issue from the installer error.
Brian
www.BCPCustom.com
06 Cobalt SS
4cammer72 Offline
im running potenza 235 50 16's on the back. but the speedo is of about 5 mph at 70, they look great but that is the only drawback i see with them
darkthunder Offline
I have 245/45/17 Sumitomo's (sp?) in the rear on 17 x 8 wheels. I had to buy 1" wheel spacers because my passenger side exhaust is too far out. Driver's side fits fine.
darkthunder - 85 TC// 302/C4
2009 Subaru WRX//daily driver
grey88smokin Offline
I usualy run Goodyears because they are cheap enough to burn and handle well. @ around 85 a piece they are not bad at all(stock size). Turning on the throttle if the back gets away, the rear comes right back behind ya.
I am running the snowflakes in the rear now with el cheapo tires that don't hold the road for anything. The rear will sway back and forth.
I know Goodyear is not a world class tire but they work for me. If your not running a good tire, wider ones might just smoke more in turns. A good set of stock size tires would be a step in the right direction of your not already running good tires.
84 SVO 1C
08 MKZ
t-bird88 Offline
I am running a set of Falken ZIEX ZE 502 225/60/16 on my snowflakes. My car sticks to the road when it is dry or wet. It makes little difference to these tires. I love these tires and at $90 each, I love the price of them also. I will see about getting a pair of 235's later for the rear.
Just my $0.02 worth.
Jim B Big Grin .
Gunmetal Grey 88 TC!!!!
PetzJC Offline
See my signature....I love them, with no issues.
Polyurethane bushings throughout, Goodyear GT-HR 235/55R16
bhazard Offline
245/55 would be closest to stock diameter, if anyones wondering.
Im not a fan of low pros, huge wheel well gaps are ugly.
svo_thunderchicken Offline
the extra height the 55 makes over the 50 wil make the edge rub... on fronts at least
84 TC Silver 5 speed - PE EEC, Big Vam, RR cam, 35lb injectors, E6 swap, T3 60 Trim, 87-88 intercooler and hood, BOV, K&N Cone Filter *under constrution*
http://www.cardomain.com/ride/2298891/1
87 TC Black 5 Speed - Stock IHI, BCS Bypassed
http://www.cardomain.com/ride/2390431
