Ride Conrol
natomember Offline
Recently purchased 88 TC. Car runs great except for one thing, ride control! I have an 87 TC and in the decade that I have owned it ride control always worked great with 110k plus. Thinking this is no great problem, changed ride control switch. Put in known to work ride control computer and relays. Last owner installed new adjustable shocks, can anyone shed some light on this?
Joe H
martin0660 Offline
The million dollar question, did the previuos ownder install PRC adjustable shocks or something else? Pop off an actuator cap and see if they are hooked up to anything. There is a good chance they went with the Monroes or manually adjustables because of availability and cost.
Bob Myers
My 88 Thunderbird TC Pictures, Updated 5-8 with a few drag pics
natomember Offline
Removed actuators, they are motorcraft adjustable shocks! Is there a way to set the actuators and test actuators?
Joe H
[This message has been edited by natomember (edited 07-09-2005).]
On the bottom of the activators there a an S and H marked (soft and hard). If you look in the little tube sticking out, you will see a shaft with a rectangulat slot in it. This slot fits over the flat adjuster in the top of the shock / strut. Slot in activator should point to S in soft, and H in firm. When you switch it from auto to firm, you should be able to hear the activators click, as well as the relays in the trunk.
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 23 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 04 Taurus Duratec (wifes car)
natomember Offline
Sorry for the delay, but I recked my 87 turbo coupe on I 81 during a rain storm. Wondering whether to total it or not. In the meantime, I found my replacement ride control switch was defective. Eliminated it and wired it direct. Never used the auto ride anyway. Guess that is why the previous owner put new ride control shocks on it. Thats a rap!
Joe H
trbocoup Offline
sorry to hear about the total. i've been there. glad to see you are ok......james
Just because you're not paranoid,....Doesn't mean they're not after you!
