fordtech58
Apr 2002
Pukalani, HI. U.S.A.
How common is a harsh gear clash when selecting reverse? My wifes 85 is a problem for her , are there any cures , tricks or fluids that work better than others? The clutch is fairly new though I do feel it catches to close to the floor, only about 2 inches of pedal and your rolling. The trans has a new steel bearing collar Fluid is fresh with spec mercon. I also have an 86 with the same concern though mine is not as bad. Any ideas would be helpfull or is it just a fact of life? Thanks Rick B.
85 Elan 5.0 Mine since 86
85 TC 5spd. Wifes toy
86 TC 5spd. 1 owner Calif
86 TC 5spd. pc/rotted
88 TC 5spd. pc/rotted
93 Aerostar family hauler
01 F150 Supercrew towrig
84 RZ350 Yamaha my ride
81 Ltd440 Kawasaki wifes
registry loves us !!!!!
80 Buick Dragcar 440ci Chevy [email protected] (was originally a turbo)
Going into 5th and then reverse works sometimes. Let the clutch out in neutral and waiting for the trans to stop sometimes works
Dan E
Greensboro, NC
Yep...no synchros for reverse.
I'll grind it occasionally if I'm parallel parking or something when you have been going in 1st and then try to go into reverse too quickly.
Like Pete said, wait a couple of seconds for the tranny to stop before going into reverse.
Dan Eaves
Dan Eaves
My reverse used to grind about 75% of the time shifting into to it, under lots of different circumstances. Now I just slide it over, go into 5th then back down to Reverse and it works everytime with no grinding.
TCx2
Sierra Vista, Arizona
Interesting that some folks talk about going into 5th then to reverse. In my TC that isn't possible. There is a form of lockout I believe. Put it in 5th and reverse is no longer an option.
Kevin
TCx2
67 Green Ford Fairlane 428CJ 5spd
89 Fiji Blue Chrysler Conquest
03 Mercury Marauder "Supercharged"
03 Ford Excursion(King of the SUVs)
04 Mustang Cobra - Screaming Yellow
10 Challenger R/T "Supercharged"
Blade1433
Jun 2001
Columbus, Ohio, USA
My TC doesn't have the lock out, however, my Isuzu did...
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy, almost all options with new U-joints, tranny Xmember, front end, FULL tune-up with select MSD products, new horizontal axle shock thingies, custom interior, white face guages. Coming soon: boost guage and air fuel ratio guage on the pillar, Gillis valve, K&N, gutted upper, knife edged lower, gutted E6, T3, and steam cleaned engine bay.
85turbotbird
Mar 2002
Woodbury, MN
I have an '85 that has the same problem, I just put it into first before reverse. Works for me.
Tadd
85 turbo coupe
beats an f-150
gets roasted by a supra
natmac3
Mar 2002
Aberdeen, MD
The 86, 87, and now the 88, ,have all done the same thing, and sometimes, when going from 5th to rev. it will lock out, but hey-sometimes when going from 2nd to 1st downshifting at lights, it will lock out. Let off the clutch very slowly and just barely, and gently ease it into gear, works for both problems...
1987tc
Dan E
Greensboro, NC
Now that I think about it...I have to do that too occasionally to get mine in reverse. It's just become such a habit I didn't even think of mentioning it.
Dan Eaves
fordtech58
Apr 2002
The 5th to reverse is working great for her. I haven't tried it in mine yet, still doing freshen up maintenence. Thankyou to all who took the time to reply!!!!!!!!
Rick B.
